It first i try so many times and after i was going to give up on this... something tell me to turn on my wifi after that root worksI had trouble getting king root to work.
Some helpful tips are to turn WiFi on, restart your phone, use task manager to clear the cache and data for king root then run it!
TkanksIf this works I will add the B06 modem flash to the root instruction if anyone plans on flashing a custom ROM.
Did you make a nandroid before you flashed broken os?Ok so i am on Tmobile 4.4.4 b33 rooted. And i flashed broken os, but no sound during phone calls. I know its a modem or radio issue. I wanna know if you can make a modem flashable zip for this one aswell.
But why? Does it have ROMs?
The problem is that the modem you have is not compatible with our ROMs. If you have MetroPCS flash this one. https://www.androidfilehost.com/?fid=24269982086991464Need help... i flash BrokenOs everything is working except i can't hear anything when making calls. I can make the calls but is like i have the volume completed down but isn't, is completed volume up.
If you have T-Mobile flash this one.
https://www.androidfilehost.com/?fid=24269982086991623
We can root B.33? Without bricking?! Yes!Ok so i am on Tmobile 4.4.4 b33 rooted. And i flashed broken os, but no sound during phone calls. I know its a modem or radio issue. I wanna know if you can make a modem flashable zip for this one aswell.
Actually? How did you root B.33? I have no root strategy available for it. I was planning on helping masterchief with getting him the modem files and the rest. Guess not.Ok so i am on Tmobile 4.4.4 b33 rooted. And i flashed broken os, but no sound during phone calls. I know its a modem or radio issue. I wanna know if you can make a modem flashable zip for this one aswell.
I noticed that BrokenOs didn't bring a music media player...Is there's a music media player without ads in google play?
I just find this http://forum.xda-developers.com/showthread.php?t=2625426 is working greatThe only thing I can suggest is try out some of them. I use the paid version of Poweramp and the paid version of MXPlayer. They excellent apps.
does this open the possibility of 12 band lte on the zmax with custom roms?
