You would have needed that in step 3 my friend.
Quite possibleso it i didnt instay the step 1 the
1.download and install htc sync:HTC Sync 3.0.555
woudl that be the reson it didnt work right in the first place
I would leave the 2 files on your sd card.so can i just redo the cmd from the command widnow or do i need to remove the files from my sd card and start over
No, that file PC36IMG will not work from recovery, it has to go thru hboot (the bootloader screen)can i not go into recovery and apply the update that way from the sd card
The PC36IMG file you downloaded from post 38 stays zipped, just renamed.should i go threw it again and tell you what it says after i enter each command
