k so i am a a lost end what can i do the only thing i can do is go threw the commands and as i do them give you the reply to the camands as i enter them
No need to do that as it should look like what is in the original post of the Taco Root guide.
I know you are frustrated and I can understand that, heck, you've been at this for at least a day now.
I can only say, take a deep breath, slowly re-read the instructions.
I personally have not used the Taco Root method but I have that guide pulled up on another tab on my computer trying to go thru it with you.
It seems like you get stuck at step 14...(Edit: sorry step 16, not 14)
I am trying to understand what could be the issue here, believe me, I want this to work for you and when it does, you will be pleased.
I cant ask you if you did every step and I cant ask you if you downloaded every needed file, our posts would be a mile long.
But so far, it seems you are doing everything correctly, but step 16 is a stumbling block for some reason.
Dont worry, relax and we will figure this out...we ALL will. k?
