Whats the difference from titanium backup pro and regular titanium backup
Okay guys it should not take forever when you press root, mine did and i uninstalled it and reinstalled it and it worked. !!!!
THANKS EVERYONE
You can try the free version of Titanium Backup but I think that to do everything you want you need to have the pro version. SetCPU is what I used and yes that's the one.
You can restore uninstalled apps if you backed them up first with Titanium. When the new upgrade comes out it will be necessary to do that with some apps. And you will also need to unroot. This is easy. The main thing is not to remove any critical stock app that came with your phone.
These are not so easily restored.
It's not a big deal really. When the upgrade to 2.2 is released there will be plenty of people here to get you through it.![]()
wow such great information, thanks jazz!
Question: is setCPU the only program that will allow cpu overclock on the ascend, or is there a free app that is compatible? I really want to do this, right now, but I can barely afford to pay attention until payday.
Also, I understand that rooting the phone voids the warranty, but can they tell it has been rooted in the past if you restore to factory before taking in for service? By the way I registered for this sight based solely on the information provided in this one thread. thanks again.![]()
I have had semi success with Barnacle it works then does not work , anyone use a mac with it ? Seems like im online then offline, then online, then offline ...lol
I just got the huawei ascend from cricket and I want to root it...help!
Thank you....gonna try it and get back to ya.![]()
Yes yes it isLOL I know !!! Like I said...it's gonna turn out to be the best Tutorial on rooting your phone there is!
Thanks to you and your patience!!
!!!!!!!Yes yes it is!!!!!!!
what do you mean, "leave it at the minimum"
do we put both sliders at 600? or only the max slider?
sand what about the minimum slider? How high/low do we set the minimum slider at?
Soo.. I've read this whole thread, and just registered to the site. I've always been pretty technologically advanced but I do have a question..
Btw.. thank you guys for all your help I was have the same problem as mister jEFF with the tethering a few weeks back and contacted EVERYONE and no one could give me an answer.. But I Rooted with z4 and got rid of bloatware and overclocked to 600.. But im using Launcher pro and better keyboard 8 (Gingerbread ed.) bc it looks soo much better, but its still running a bit slow esp. when I click to go home, I barely have any apps on my ascend but I was wondering if anyone knew why this was?
Hello all, I'm new to rooting, and bad a couple ?s...1. Is there a newer version of z4root 1.3.0 that i should use. 2. I can't afford to buy any apps at this time, so do i need titu Pro or is there another free app i can use?
THX IN ADVANCE!!!
Thx a lot, and thx to all who put time into this forum to help folks like myself!!!! I've been reading the forums for a couple of days now, and even tho all the instructions are pretty clear, there's always some questions i have to ask, just me. So i was wondering are there any new steps i should follow when rooting or installing cm7, the newest version, since all the instructions are dated oct-jan?
