Stumcmahan
just got it to restore an old backup i made with twrp a while ago.
i did redownload them and i'm redownloading them as we speak. not sure what md5 is.
ok i downloaded the md5 checker and installed it. i understand its purpose but don't get where to find the #
it is found in the op of the rom.
thanks man but this isn't helping i'm assuming op is original post of the rom which isn't helping me. never checked a md5 before i have no idea how to check it.
yes op=original post or it can mean original poster depending on context.
if you look at my previous post i have the md5 checksum. it is found on the dev host site where you download the file.
ok that is good at least.......so you can't flash it then?hmmmmm i wonder if you can try and downgrade twrp. there are some funny things going on with the latest ota(i know you did not flash it) and twrp. it could be the any 3.15 rom will not flash right with twrp 2.4.1.0 maybe try twrp 2.4.0 instead.....just a thought.
i could try that but isn't meanrom a 2.13 rom not 3.15? and it won't flash either. do you know where i could get a flashable twrp 2.4
weird i thought you tried mean bean and not the mean rom.....oops
well mean rom should work not sure about the latest twrp(it was just released recently). but you can go here for most things:http://androidforums.com/evo-4g-lte-all-things-root/614073-list-utilities-roms-kernels.html. go to the utilities section. there should be a twrp link in it. also here is the teamwin's website(the devs behind twrp)TeamWin Projects - TWRP 2.4 - | TeamWin
thanks dude that was it! i downgraded to twrp 2.3.1 and it flashed properly. just finished booting up. good looking out man.
