Hi everyone,
I've had my Galaxy S2 for a few weeks now, love it and it's so much better than my old Desire HD.
There are a few questions that I haven't been able to find answers to, and I've looked across various forums.
1. Is there a way to make the incoming call contact picture bigger? Default picture size is very small and quality on screen is poor, regardless of the size/quality of the original image file. I know that there is an app called Full screen caller id, but I would like to avoid it if possible. HTC sense gives a much nicer incoming call notification.
2. Samsung stock photo frame widget - regardless of the size and quality of the selected picture, on screen it looks very poor. Even pictures taken with a pro DSLR, resized or original size, on screen appear to be low resolution and not sharp at all. It doesn't look anything like the on screen photo in S2 ads.
In the gallery however these same pictures look great. Am I missing something?
3. Stock Samsung weather widget - most of the time it fails to auto update using data connection. Also if I click on the update button in the lower right corner of the widget it always says "connection failed". If I tap on the widget (i.e. open the app) and then select update it updates as it should. On top of that the shortest auto refresh interval is 3 hours, so most of the time I have to update manually.
Is there a way to fix this as I really like the look of this widget?
4. Stock browser - It makes the newly opened tabs active. Is there a way to avoid that?
Thanks for any help on these issues.
