Welcome to the forums!
This worked for me.Actually I found a very easy fix for me. Worked like a charm.. Simply download "rotation lock adaptive free" from the play store. Set it to "stock auto" and hit save. Then test it out. As you can see its not hardware at all. It's software. Now to perminently fix the issue, simply uninstall "rotation lock adaptive free". Since you saved the setting as "stock auto", it's using the stock rom's auto rotate. Un installing the app simply keeps the auto rotate working and locked it back in place. You are now good to go and you don't have to wipe data. Hope this works for everyone like it did for me.
No need to download anything. Just pull the screen down to expose the settings cogwheel. Under that are 5 buttons with Wi-Fi at the left and Wi-Fi Calling at the right. To the left of Wi-Fi Calling is a button "Auto rotate". Just press to activate -- it turns yellow -- and the problem is solved.First, the screen rotation is on. But photos, webpages, most apps will not auto rotate when I turn my phone landscape. Only app that it works in is you tube, when you view the video in full screen. Then it tends to lock up and get stuck. I've done all the software updates, rebooted a dozen times, turned auto rotation on and off .... any advice?
