biggiephil
Hey :l sadly my charging port on my motion is starting to die, have to keep it at an angle to charge :/. Has anyone else had that issue? I think its time for an upgrade.
Time for an upgrade.. I was in a metro store about 9mos ago and saw a guy having the same issue. If you have insurance you can get it replaced with a $39 deductible. I think it's time to get an l9 though bud!! Lol
yeah L9 it is ^-^ thanksOnce you use the L9 daily, the motion looks like a piece of junk
Sadly, this is true. The resolution is so bad on the motion...and so blurry..how was I able to stand this![]()
Hey awhile ago i had an optimus m the charger port was getting sloppy.
i removed the back plate and soldered a mini stereo jack to it to use for power.
i had a small hole in the backplate for the 2 wires then glued the jack to the back of the plate. the only drawback is you have to be careful when taking the backplate off to remove the battery.
this would be nice to do for the motion so when using it while charging the cord isnt hanging off the side.
You don't need metros insurance. Lg has year warranty on this phone. Metros insurance is a complete ripoff. Go into the store and tell them the phone just stopped working and you want to send it back to LG for a refurbished one. I did! Only drawback is, you have to wait a week for the phone to return. And you can't buy a new until it comes. So just use a old one until it comes or buy a cheap one before you turn your broken phone in.Hey :l sadly my charging port on my motion is starting to die, have to keep it at an angle to charge :/. Has anyone else had that issue? I think its time for an upgrade.
Do you use a case? Just fyi always gently unplug it by pulling it at the point of connection and never lay around with it on your bed while sleeping or anything similar. Always plug it in and lay the phone on a flat surface like a table or nightstand.
I do have a case yes, and yeah I do gently pull it out just in case and ok![]()
The guy that I saw with the problem had the problem because of his case..
Hey bro!you should try another charger,I did it with mine a while ago and my phone gets charged just fine
