TheGreatZhuzhu
Will a class 10 scandisk work on the triumph?
if not what is the highest class (or fastest class)the triumph can handle
just get the SIZE card you want
This, really, is the most important thing. Better to make sure you spend your money on the size of the card instead of the class of the card.
not necessarily true i had a bad experience with a 32gb class 2 memory card i had to return it cause the transfer rate was so slow thats when i decided to bump upto class 10 best decision ever that thing flys lol
. I would avoid class 2 though.
