Root Screen is unexplainably stretched
So I woke up this morning to find my beloved Ally's screen is stretched out so that the top half of the image is stretched to fit the whole screen, and the touchscreen works just fine, as if there is nothing wrong with the image on the screen. I'd take it to Verizon for an exchange but I am running Velocity 1.1 and am not sure how to go back to stock if the screen is virtually unusable... :confused:
I have absolutely no idea what in gods name you mean by this.
but if its what I assume you just need to set the lcd density with my scripts
Imagine that the bottom half of the screen was cut out, and the top half was stretched down to fill the empty space.
This is probably the best way that I can explain it.. the screen only shows about half of what it should, and it is stretched out and pixelated. However, the touch screen works as if everything on the screen is where it should be. I hope this makes sense, I'm extremely frustrated haha
Solution 1:
  • Reboot into recovery by pulling the battery and powering on with SEND MENU END combo.
  • Wipe everything and reflash
    OR
  • Restore a nandroid
Solution 2:
  • Install ADB
  • Connect phone with USB
  • launch adb shell
  • type velocity
  • set your lcd density back to 140
Solution 3:
  • Install ADB
  • launch adb shell
  • type nano /system/build.prop
  • edit your LCD density to 140 or lower
Solution 4:
Solution 5:
  • Use D2A or Tridents guides (LGNPST or LGMU) to restore the phone back to stock V6
Solution 1:
    OR
Solution 2:
  • Install ADB
  • launch adb shell
  • type velocity
Solution 3:
  • Install ADB
  • launch adb shell
Solution 4:
Solution 5:
Thanks a lot man, I'll give these a try. It'll be a pain in the ass to do all this when I can't read half of what's on the screen, but hey at least today is my day off
Ummmm.... If you get into recovery and your screen is still messed up something is HORRIBLY wrong, and your best bet at that point would be to brick it and send it in for warranty
Apologies for not mentioning this before, but the same problem happens when I am in recovery..
..so how does one go about bricking their phone? Sounds like my only option at this point and I'm not at all opposed to it.
Easiest would be fastboot, you can just erase the partitions with it, but if you dont have the time/knowlege to get fastboot working, you could use LGMU or LGNPST, either will put you at V6 stock - which is just as good for warranty. Or you could just SWC's nandroid
LGMU let it start flashing and just as it begins flashing rip out the USB cable.
I say LGMU because i have yet to get LGNPST to brick a device. Hehe.
