lMonsterl
Android Expert
Changes to DM so you can connect your phone through COM port. You can change your PRL while using CM7 w/o changing back to stock or Ct mod. Thanks go to the new optimus for sharing what he found and to the devs, hroark, shabby, interdpth, koush
Run with script manager.
run as root or SU, depending on your version.
Step 1. Press E to Enable
Step 2. Hit N to go back to menu or Y to exit
Step 3. Move on to cdma-workshop
Step 4. Press D to Disable
Step 5. Exit after or go back.
Attention: Some users cannot use it, cdma-workshop will not read from phone or send a password to unlock it, it will however connect and set a com port for your phone. I am not sure as to why it is only certain phones at the moment. I think it may have to do with newer vs older manufactured phones or mavrikmeercat suggested it varies based on COM port, so try out a few.
Prl Downloads
Incuded Prl's are 00001,01115,01120,01337-mod,11114,11115,22081,31010-mod,31010,52341,60676,60677,60679, 60681, 61007, 61677
DOWNLOAD PRL.zip
Thanks to Capn069 for the link provided below which contains numerous sprint prl's.
LINK
DOWNLOAD
Prl Downloads
DOWNLOAD PRL.zip
LINK
DOWNLOAD
weird it says failed phone does not answer any ideas
