Do you have antivirus turned off? Or any program that could interfere with communicating to your phone like pdanet?
no need this guide here will point you in the right direction:http://androidforums.com/evo-4g-lte-all-things-root/605567-ltevo-rooting-dummies-complete-guide.htmlI do have a pc also will check that in the morning. Will type in Google to see if I can use mooshine
Vm are not supported I will check in the morning
No worries bro I was using a pc in my house now I'm in a different room with a mac that has vm windows running on it. I think I'm following you so far becuase the pdanet I had on the pc was removed and my adb still failed so it may be the firewall like you said. I did see something about firmware but I'm thinking I'm ok
I think it was on I can remove it
Well I did use adb devices when unlocking and fastboot devices. I will check tommorrow ! is there any comands you want me to try real fast to see whats wrong I can do that for the commands but not s off tonight
I solved that problem earlier but my biggest problem right now is finding a Rom that has Wifi do I need to activate ADB or something
Every time I download a new Rom the sorry Hotstop do not work
