Help SD Card
quaff1976
Just purchased an A500 and have a question about the micro-SD card.
When I connect the USB between tablet and PC, only the interal device storage shows. The micro-SD card does appear in Settings->Storage.
The user guide suggests removing the micro-SD card and using a card reader to mount on the PC. Is it possible to mount the micro-SD card while still in the A500 as is the case with most Android phones?
Any thoughts? I'm using Win 7 64-bit. I do have the USB update installed from Acer's website.
your SD card status should be shown in <settings><Storage><External SD card>
If you are using Astro File Manager you access your SD card via <external_sd>
I am seeing the same problem. I can see the A500 tablet listed and the folders and files listed under 'Device Storage', but the Device Storage link does not contain the External_SD contents. Will update this thread if I find any detail elsewhere..
Well that's just silly :(
My problem right now tho is my a500 doesn't show the card I installed. I was hopingvto format it from within the settings menu....similar to how.we do it on our phones but I don't see that option
I am thinking that you have to use a card that is already formatted.
Yeah, I was thinking that too. A few nights ago I put a 4gb microSD card in it, and since I'm on a mac, I tried to connect it to android file transfer which was working perfectly before, but my Iconia wouldn't connect to AFT anymore and I ended up having to do a factory reset (someone at XDA had this same problem, did the same thing).
I was wondering if formatting had something to do with it, though this was the same card I once used with an android phone before.
Maybe. Tried two different cards and neither worked. I am going to try and format one.....also didn't realize this thing works only with 16gb or 2 Gb cards....I have a ton of 8gb cards. O well. For the hell of it I picked up a nook color and s7 slim to play with.. winner gets to join the family.
I took a card out of an old windows phone that had music, photos, and pics on it and I was able to search the contents in astro and everything on it showed up in the gallery. Ill see if I'm able view it through the settings menu when I get home.
Is yours showing in astro? At first nothing showed up so I took it out and put it back in and it showed up.
I put in a 16gb card into the A500 and it works fine. I formatted it first just to be on the safe side.
Only thing that really needs an update is you can't see the card via USB connection to the PC, you can only access internal A500 storage. You have to remove the micro SD card from the A500 and mount it to the PC using a card reader. Once you transfer files that way and reinstall the card, the A500 will see the contents.
PITB having to remove the card to transfer files to it though. Would love it if someone would tell me I'm wrong on this. :(
Only thing that really needs an update is you can't see the card via USB connection to the PC, you can only access internal A500 storage. You have to phisicallty remove the micro SD card from the A500 and mount it to the PC using a card reader. Once you transfer files that way and reinstall the card, the A500 will see the contents.
There are some work arounds if you root.the device. Its to technical for me, but its on the xda forum.
So yeah I have a 4gig micro SD card in mine and it shows up properly both in the settings menu and in astro. In the settings menu I can't do anything, it just shows the size and remaining storage. Maybe ill try plugin it in ton the PC and see what happens.
Where did you hear about this? I did not know.
Someone on xda claimed it is in the manual.....I am too lazy to look it up lol
About to try andget an sd card working and root this bad boy .....then root the nook...then root the s7
So far the s7 runs the smoothest ....but the display on the 500 is far superior ....pointless if it continues to lag etc
I will prolly do a full write up on the three by the end of the week
Sigh, the same thing just happened when I tried to connect it to to an ext hd. Time to reset.
Edit: I didn't have to reset. :D Came across mention of XJNB from XDA by _motley and it works just fine (and looks set to be a lot better than the simplistic AFT).
For what it's worth it's threads like this that makes it a pleasure to be part of this forum. Someone asks a question and not one of the replys made snide comments or attacks. All very helpful.
Thanks all.
Thanks all.
I did think about it though, mind you I rarely read the manual...... :p ;)
have win7/64 bit W/USB udpate, 32gb Flash on ACER a500. Can see/mount from filemanager HD on device NOT from PC. So I basically just copy stuff (for now) to local storage and then move it on my device (with file manager hd)
I had put an old 4gb sd into my a500 when I first got it. I could not see it when I connected by micro usb to my pc.
I was able to see the old files that were already on the card on my a500 in various file managers.
I just bought a new 8gb sdhc sd card. I put it into the a500 without formatting it. I connected it to my pc and it shows up. The a500 has two storage drives. One labeled "internal storage" that is about 15gb and one labeled "sd card" that is about 7gb.
I copied divx movies onto it. I got a warning that the files had to converted or they would only be copied for storage. On the a500 they will play in the clear.fi player. The gallery refuses to play them. I found this odd because the gallery app on my coby tab will play the same movie files with out an issue.
Also
Wondering if anyone has quite dialed this in.
Just picked up an Iconia A500 on Friday. Had a spare 8GB micro-sd laying around from an old Samsung Captivate - still had pictures and music on it from the Captivate. Threw the card in and could see the media on the A500 - but could not see the files on the computer.
Took the card out - put it directly into the computer and could now see the files in Windows Explorer. I then 'right-clicked' the file and hit "Format"
To format it - I hit "RESTORE TO DEFAULTS". Everything was wiped. I then re-installed the card.
Still same problem. Can't say I've experienced this any of my other Androids - I've had the Captivate and currently have the Samsung Infuse.
Sno shark - Use Es Explorer.
Go to Menu - Settings Home Directory
Change it to mnt/external_sd/ - may be \mnt\external_sd\ Cant remember and tab is at home.
Then you can see your EXTERNAL SD card. Enjoy!
