I partitioned my SD card so that my apps will no take up the space on my phone. I am running mik3d B1. How can I tell if my apps are all stored on my SD and if they are not how can I move the entire app over not just a piece of it. Thanks in advance!!!!
OK thank you. Could you help me understand this a little better....
System Rom- 367 MB (15 MB Free)
Internal- 448 MB (368 MB Free)
SD Card- 13.9 GB (9.59 GB free)
SD Card (a2sd) 1.91 GB (1.67 GB Free)
So is Dalvik Cache the app itself?
another ?, or 6...
If I take a spare sd card and format and partition it and use it instead of my current card, will Mik3d automatically put the apps onto the card? Does it give you some kind of msg when it does it?
Mk3D doesn't NEED dt? But then you say it would be good to have to move the D-cache, which way are you moving it? Is there an optimal size for it if you get a chance to change it?
If you flash another rom that does have built in a2sd, are there a lot of complications?
What happens if you put the non partitioned sd back in, does the rom go nuts wondering where the apps are?
In that case, could you just restore the apps that you had backed up on the original card, or would that really blow it's mind?
Then, what is the minimum speed or class sd card you would try this with to avoid bad performance?
I don't ask enough questions, do I?
wow, a perfect 10!
I have a radio shack 16 gig but not sure if it a 6 or a 4 or what. Other spares I have are just 2's! Useless.![]()
If it does not say, then it is a 2.
It did say one or the other, I just can't remember what it said.
Don't feel like trying to pry the little bugger out to check right now.
If it is a 4 then you can try partitioning and it may or may not work out performance wise. If it is a 6 then you should be good to go. That said, I've even heard of folks doing perfectly fine on class 2 with partitioning and a2sd. So you should be good to go.
I have 2 Zio m6000. My phone came with os 1.5 and I did the up date over the air to 2.2.
The second Phone we pick up new with os 2.2. both phones are rooted. My phone all apps move to my sd card. My wifes only a few apps will move. I load the same app On both phones and I can move it on mine. My wife's is greyed out. I did partion the SD card on her phone the other night. still no go. I do not have my card portion (if it is is nit showing in app I check it with.)
Ok, I guess I should pull it out and back it up again and then try it.
Is there much of a speed difference with the extra free ram on the phone?
whore like Ocnbrze... or so i hear![]()
just because i have 163 apps that i do not even use does not make me a whore. an addict. yes. a whore no.
who you calling a whore?just because i have 163 apps that i do not even use does not make me a whore. an addict. yes. a whore no.
