Semi Bricked Help!
Hi,
I was trying to flash a custom ROM using ODIN but now when I boot up the phone I get a Phone - ! - Computer logo and nothing else.
I can still boot into download mode and think I need to flash a stock ROM, but I'm not sure which one's a stock one. Can anyone point me in the right direction, or have another solution?
I'm a UK O2 user if that helps.
Cheers.
Flash this with odin to go back to O2 branded firmware or you can update to the latest non branded firmware by flashing this
Been looking for the same O2 branded my firmware as the same of my phone, as I'm thinking about trying a custom rock and wanted this in case I needed it and your link took me to it. Thank you.
Hello, I'm trying to flash my device to: GT-I9100_XEO_I9100XXKH3_I9100XXKH3_I9100OXAKH3, but after odin completes the phone throws an error something like "cant acess: system/csc?/H3G/SYSTEM????" (its too fast) and them I'm stuck in a boot loop.
A little background:
I rooted, unlocked, installed cwm, downloded modaco custom rom and put on external sd. Booted cwm (forgot to back up:eek:) factory reset, wipe cache, and dalvik. Then found CWM couldn't access my external SD. OMG
Any ideas?
Do I need to re-partition also on Odin?
Any ideas?
Hi Batfink!
Boot into recovery, connect to the PC via USB, go to "mounts and storage" and select "mount USB storage". You can then copy the Modaco ROM zip to the removable drive with Explorer and try flashing it as CWM will recognise /sdcard okay.
edit: DO NOT repartition with Odin unless specifically instructed to!
