Do I remember correctly you trying Mikg, Decks reloaded, different kernels etc and also do I remember you letting kernels settle in etc.?No matter what kernel sense kernel I tried I dont get good battery life![]()
I recommend and Anker 1700mah battery for more longevity without the bulk. (thats what I use)
Or, a 3500mah battery but adds bulk (need a bigger battery cover with that)
Well, for me, the stock battery, on average, lasted about 12 hrs with my average usage.How much longer does the anker 1700mah battery give you over the stock battery? I only have the two stock ones that came with my phone, but I'm considering getting an extended one.
The Anker, with no change in phone usage habits, lasts about 16 hours or so.
So, those 4 or so more hours is worth it for me.
What is your average battery life?I have setcpu max 499 min 245 ondemand, deadline
Classic rom + chop suevy kernel
I have everything off I only turn 3g on when needed
Are you doing a lot of gameing? thats a huge spread on time.No wakelocks and with moderate use about 4 hours with out moderate use about couple days
Yeah I like digital karma but trying classic and am i able to flash netarch I don't think I can because its froyo and what combination was it
My best battery ever on my normal use was tommy tomatoe and aggressive freedom.
3.5 days.![]()
I get around 2.5 to 3 hours of screen time and 4-6 hours of awake time on my anker 1700 battery but again, it all depends on how I'm using it.
I get that using the stock battery. What are using mostly when screen is on?
