I have a problem trying to overclock...I am using some of the netarchy kernels and whenever I try to move the bar in setcpu past a certain point my phone locks up.
not sure what happened. but one thing is that you should not have a whole lot of profiles setup. they can actually create worse battery life becuase it is constantly looking and checking and never really sleeps. also in order to underclock in setcpu you have to disable perflock. if you want to overclock then you need to have a custom kernel.
havoc...
thanks a bunch for the advice.
i'm trying to keep my app count down so as not to clutter or bog down my evo.
specifically, maintenance apps.
just to be clear...you're saying flash havs kernel and do not use setcpu?
edited:
just read mroneeyedboh's [GUIDE]
Just some info for people that might run into issues using profiles. I've came to the conclusion on the 3 EVO's I've rooted now, that when using Netarchy 4.3.2 HAVS kernels, we get better battery life without running screen off profiles. I had the profile set for 245-384. We've seen about 50% better battery life, before 12hrs max now about 18hrs easily. On my phone I played with the limits of the profile, but didn't have any different results even going up to 652. Also, I haven't had any issue with the clock occasionally locking up like I originally had when waking the phone up, again on all 3 phones.
Does this go for the 2.6.32.27-netarchy-toastmod-4.3.1-cfs-havs-nocbc kernel as well?
I would just like to know if anyone has tried 2.6.32.27-netarchy-toastmod-4.3.4-cfs-havs-more-nosbc (More Aggressive HAVS), and if so are you using SetCPU and if so what settings did you go with? I just installed this kernel today to see if I can get some better battery life with it. Currently I have SetCPU disabled.
***UPDATE***
After installing this kernel I had high battery temps and no better battery life than with my previous kernel. I went back to the 4.3.1 and after a full charge my BMW says I have an estimate of 1 day usage.
worth noting..any CM7 based rom has these functions built in.. ... oh and there is a new CPU over/under clock app I have been playing with...no frills CPU control.
no profiles ..but I have never used more than screen off anyway.
Hmmm... Not sure. You didn't use the ota update did you? If so, you'd have lost root (and a new hboot).Anyone know after the most recent Gingerbread flash update business I did why I can't disable perflock using SetCPU?
