did u check latitude? and skype runs in the background even when its not signed in, which is a bug or something..u can force close it when ur not using it
After another full day, I get 7 hours with Android OS consuming 85%
The longer the handset lies idle the higher the Android OS percentage will be, as the majority of tasks/processes running are those requested by the OS itself.
Are you still seeing a high wake percentage? If so then you've got a wakelock issue with a particular app; something like Better Battery Stats or Spare Parts will allow you to work out which one is preventing the handset sleeping.
i had a similar bad battery life. did a hard factory reset, through some short test with bugger all apps on it seemed the same. took it to the samsung center - techie did a quick test to find a "higher than normal" voltage drain. its in the shop...waiting for outcome.
I suspect the cause to be the power saving notification, which keeps the CPU and display awake. The battery usage indicator shows a solid line for - Display & Awake right about the time the PSM is activated.![]()
Hi All,
I have been using the Samsung Galaxy S II for 2 weeks now and am getting very poor battery life. On an average of 16 hrs max is the time before the battery drains.
I dont have a live wallpaper ( have a black one), have juiceDefender installed, and have brightness set as 0.
My Battery Usage is as follows,
Display - 50%
Android OS - 3%
Android System -4%
I use task killer regularly.
Is there any suggestion to reduce the display power consumption and to increase the battery life.
