am i like a ghost or something WTF!
Been rocking metropolis the last couple of days has anyone noticed battery draining at a faster pace than other roms I don't turn off sync or anything like that just lowered screen brightness a little maybe that's the culprit any input from anyone using metropolis
On another note, this is cool.
Saving my dough for this.
SGS3 MOD: Galaxy S3 i9300 Wireless Charging Kit with QI Technology
HIGHJACK!!!!!!
its just a simple typoHii I recently just installed this rom but I keep on gettin the base as 4.1.1 instead of 4.1.2 any suggestions? ??
Btw I installed metropolis version 1.5
because you arent supposed to wipe systemCan anyone help me on the steps on how to install this rom because i D/L 1.0.5, it should be the same installing CM & AOKP and i tryed flashing it and it said failed . Did the 9 yards wipe This wipe that. And good to go.![]()
So pretty much its the same stuff wipe del, wipe cache, factory ....
and thats it.. and just flash right?
Ok i flashed it with out system wipe and it said sucessful and then it got stuck on load sgs3 screen.
Back to stock root.
Please tell me what im doing wrong
If you like, you can try an app like Pimp My Rom from the playstore. It installs scripts and tweaks that are supposed to help. Results may vary.
Does Pimp My Rom really work. Did some checking out, & it seems a lil far fetched. I mean, if it's so good why aren't more people praising it?
Back to stock root.
Can i use Metrojam Theme (1.0.4) into Metropolis 1.0.5?
next version is gunna be a real shock for people who wipe system![]()
dont worry next version will handle all of that
i keep telling everyone the script will handle the install and dont worry about wiping anything unless you want to after. next version is gunna be a real shock for people who wipe system![]()
