[SGS3-R530M] Metropolis Rom [4.3 Touchwiz]
Fixin to give the new Meropolis a tryout. Used the other versions with pretty good success.
OK, I backed up all the apps I wanted to save to my sdcard so I wouldn't have to go through it all from scratch, especially some of my games lol. Now, when I loaded ROM toolbox & went to look for my backups, they're not there. So how do I get them back. I know they're still on my card.
Hey forget it. LMAO, they just showed back up. False alarm. Now to put this baby through its paces
I really love this rom, I especially love the hold the volume up to skip track on Pandora.
The only thing I noticed that doesn't work is the 4g hotspot. I tested it on different devices and none of them can obtain a ip address.
I went back to stock 4.1.2 just to check it wasn't because of the last update. But nope, it worked just fine on stock.
Not much of a biggie because if I need to use the 4g hotspot I'll just flash the my backup. Just kinda letting you know if you didn't already know. Plus it would be cool if it did work :P
This rom is nice, I am using this with the metrojam theme and I like it. I had a couple reboots at random times at first but not anymore. Thanks Shabby
Make sure you have these options enabled to make it work. No credits to me I'm trying to find the person that shared these settings on this forum with us so I will edit this post when I find his name lol
Ok found his name is cheric951 all credits to him he shared these settings on another thread and as a man of my words I told him I would give him credits for such awesome findings :D
:( starts but with errors
found an issue with roaming data, when im at work it says no data due to roaming. i go to settings and check the box "data roaming". the setting doesnt stick, i keep getting the msg.
any one else have this issue?
I'll upload the build I'm using not sure if it will matter but perhaps since mine works flawless for me there might be a chance that it will as well work for u.
http://db.tt/oad0g5e7
try rebooting happened to me once but I think it's a bug with metro pcs 4.1.2 in general not something shabby did on his rom.
So just install and start tethering? Do i have to change the settings again like one you posted last time?
Never mind i got it working:) thank you!
now if your gonna tether on your pc or laptop remember to change the user agent on your browsers or else you will get a white blank page.
