SeducedByBacon
Member
Is there a way to add apps to the pop out list? I assume its just System Apps? Could I just put what ever app I want into the system folder, reboot and it will be listed? Or is there another way??
Using the Edit button at the bottom of the side bar
I swear lol Those apps weren't there 5 mins ago!! Sigh... :stupido:
Are there any screen shots available? Was thinking about installing this rom for a bit.
Thanks,
no you cant kill teh app currently running
Ah ok...I guess that's only on aosp then...great work on this man...it's very fast and has good battery life...
it does have the note camera i believe bromine work fine but no note camera ? do i have to do something else to get
This is based off tochwiz right? So does it have the motion features like wen you screenshot by swiping the screen?
Yes it does and then some![]()
