[SGS3-R530M] Metropolis Rom [4.3 Touchwiz]
I know it's not proper but i went through and rerooted phone and the this on my phone with factory reset worked out for me just wasn't feeling like backing up since i used shabby's 4.1.2 jb tar to reset my phone last month figures I'd give it a no wipe flash always worked on the esteem for me and 3 manual reboots with no issues
Hey,
Im on the latest version but I cannot find where to turn multi window on
Do you guys know where?
Hold the "back" soft button down for a second or so. It'll pop up.
If not, go into your settings menu and make sure it's enabled.
Arocker do what kernel do you recommend for best use on this ROM?
The kernel it comes with works great.
Ive read that others have used a kernel made for uscellular S3s...their S3 is closest to ours but I havent tried it with metropolis, only uscellular roms.
That said...there are no custom touchwiz kernels available specifically for our phone at this time.
Ok so I downloaded 1.2.0 today itried this version like 2 weeks ago and it kept saying failed even after data wipe cahe wipe and dalvik is there a certain way to flash it or is the file just not liking my phone?
I would try downloading the rom again. If you downloaded with 4g try with wifi. Or try in a pc if you can. Also what was the failed message?
new updates coming full premium suite along with new modem and kernel :D
Thanks! I'm guessing what I need us the one with long sms to mms disabled since they don't send? ??
Oh...im sorry I missunderstood you...yes in that case try the first download. That one has long sms to mms conversion Disabled. Try the second too if you like...its from Metropolis so it converts long sms to mms but with extra features. Maybe that will work too. Cause if I'm understanding you...you cant send any long sms...it doesnt split it or convert it to mms. Is that right?
