[SGS3-R530M] Metropolis Rom [4.3 Touchwiz]
Oh...im sorry I missunderstood you...yes in that case try the first download. That one has long sms to mms conversion Disabled. Try the second too if you like...its from Metropolis so it converts long sms to mms but with extra features. Maybe that will work too. Cause if I'm understanding you...you cant send any long sms...it doesnt split it or convert it to mms. Is that right?
Yeah doesn't split it turned into MMS but then the MMS would fail to send which is weird because I can send picture messages just not long text. By the way I tried the first one with the MMS conversion disabled and all it did was delete the current messaging app that I have but when I go in to rootexplorer and search for it the MMS apk is there and when I tried to install it says installed failed and I have no messaging app...
I'll try the second one though.
In this case because youre trying to install it in axis rom you have to follow the install procedures of axis. Wipe, flash rom, flash patch, flash mms mod, flash kernel, reboot.
Try that :)
Also lets take this to my thread.
Try that :)
Okay so I have to do all that :( anyway I can push to system/app??
Try that :)
So I have to do all that :(. Anyway I can push to system/app??
yes its a official ota update from metro and yes the texas ninja has struck again and credits to him.
finally metro doing something good for a phone =D big success with s3 they made a god choice bringing it to there selection and good choice keeping it up to date;)
Ok I had lean installed on my number two rom and it worked great will it help increase battery life with it and how is it with out it?
Never tried the ROM without the Lean Kernel so I don't know what the difference in battery life would be if you compare the 2.
Lk+Metropolis=great battery life.
What other mods or add ons work with this Rom I have ink effect weather mod and the metrojam theme already install just curios on what else might work
Lots of mods will work...tweakbox, xsposed mods, morphology themer and patch, there are many. Lots of them are not represented in these forums. Check the sprint sg3 area. Not all mods will work but some will. Check out xda for sg3 mods. Be carefull
hey guys i just found out wifi direct does not work =/ is there a fix for it on the next update?
i'll try mine out right now to see if its just you. Then it could possibly be fixed for the next one.
Edit: tested it out. Didn't give me the option to share if i went to my gallery. When going to the Camera and then choosing a picture it showed up as an option to send via wifi direct but every time i tried to select the other phone, it would freeze and then give me the popup that Settings had an error and closed.
Its exactly what happens with me:o
