I was using my phone one day and then noticed this tab on the left of my screen and when I clicked it, it had all my apps and I was able go use multi window but it was only for a little while. I searched how to enable multi window and it should be in the toggles of the notification bar and I don't have it. Anyone ever ran into this? I like using multi window but I was only able to use it that day.
Well Im running 4.1.2 stock, rooted with some bloatware frozen.
I want to try out shabbs Metropolis Rom.
So which recovery should I install?
On metropolis does bluetooth work? I read the bugs part on his thread but I just want to double check as I use it quite often.
When I flash it over is it going to format my internal memory? I flashed 4.1.2 using mobile odin. And although it shouldnt have wiped the memory, I was one of the few unlucky ones that it did.
Anything else I should be aware of for a smooth transistion?
1) any custom recovery is fine
2) i use a bluetooth headset and bluetooth media speakers and both perform flawless for me
3) you will be using a custom recovery so the only way it will get wiped is if you do it (i do however recommend doing a factory reset when you install the rom)
ive also merged this thread into my rom thread so that other veterans of my rom can assist should you have any other inquiries![]()
Hold the back key. You should see the tab pop up again
gimme your google login info and i can set up a reminder, pay no mind to the additional charges![]()
I've been running Metro 1.2 for over a week now, and all I have to complain about is that it DOES NOT tell me how awesome I am at EXACTLY 3:15 pm every day.
Shabby, is there ANYTHING that can be done about this major issue???
It's really troublesome, ya know... not sure I can live with this.
