Is the weather notification working on the lock screen mines does not?
Hey mike I was having the same issue. Make sure you set up the touchwiz weather widget app than it should work.
cant seem to get past Galaxy S III screen, after flashing it stays stuck on this screen for more than 5 min. should it take this long?yea im stuck on this rom just has extra stuff i havnt seen on any rom. and the gallery has previews on the side which is cool and the music player wow what a nice change.
Been trying 1.0 where is the link for 1.01?
Has anyone seen this
yep this has lots of flickers in it and don't even see the LTE options on data..going back on US.c version till something better comes along...
Yeah you get thay message when you set any app as default. It's telling you how to undo it in case you want to use a different app later.
I had a little flickering before shabs update patch but now everything is good. Good battery, good gallery, good camera and able to make phone calls. Oh also no problem with stock music player here although I deleted it I like aftermarkets better. (I deleted exactly 89 bloats from system files)![]()
im really confused, the only flickering ive noticed was in gallery
Thanks men yeah after the update shabby posted it got a lot better I might have to go through and take off some of the bloat do you have a list you might recommend
mms doesnt work
