Okay, let's see if this clears it up a little bit. In Sense, you have a certain number of signal bars, usually more than four. You *can* just edit the pngs to have fewer (four for example), but the system still has to be configured to use only that number. That being said, the signal you see in a Sense ROM includes only what you need for voice (1x). I'm sure you've heard before that Sense ROMs don't tell you if you're actually connected to 3g or not. Basically, they show a 3g icon all the time if you're connected, whether it's actually 3g or not. This is not factored into the signal. On an AOSP ROM, the signal you see factors in 3g, which will always make it look lower, when in reality, it's just more accurate of your real connection. Once you lose 3g, your signal will look way lower than on a Sense ROM, and it will actually tell you that you're no longer on 3g. This is what I was referring to, mainly, and doesn't really make the number of signal bars much of an issue.
