swc2001
Android Expert
Well So I dont know if this is needed or wanted but I have taken Drellisdees files and mish mashed them to make this zip and renamed it.
What this does is Allows you to use either ClockWork or Aloha Recoveries to Flash this zip and then you will be at Stock Recovery for OTA update purposes, or what ever reason you would like to have Stock Recovery. (**EDIT** Even though it is named Signed clockwork you can still use it with Aloha. That was just poor naming on my part.**)
12-13-10(**EDIT** Ok I left out a step when your flashing signed clockwork to stock recovery.zip with Aloha. You must turn off the Verification when using this with it. This is not needed with Clock work when flashing with it though.**)
signed_clockwork_to_Stock_Recovery.zip
Again I did not write these files I did not create these files I just hodge podged them together. This is Drellisdee's Idealogy NOT MINE.
He Created them He gets the Credit and Glory. If you want to donate Donate to him.
I went ahead and made this a Thread because I have posted this in other places and has helped some people. Maybe this way It can help more people. I try to give back to the community where I can even if it is in small ways like this.
**EDIT** 1/10/11
if you have Aloha-RA 1.2.5 recovery use these steps to make this zip work
1. Boot into recovery
2. Goto Flash Zip Menu
3. Select Toggle signature verify
4. Select Flash Zip from SD Card
5. Select Signed_Clockwork_To_Stock_Recovery.zip
6. Press enter
7. Turn off Phone
8. Boot into recovery to check if it is now at stock recovery. (you should see little android with exclamation mark flash then it will boot into phone normally. If this happens you are at stock recovery.)**
All I ask is if my little hodge podge of his files helps you... Why dont you go down there hit that little Thanks button.
**EDIT** 1/10/11
6. Press enter
7. Turn off Phone
