^Many thanks - this removes all doubt of the safety of this action.
Through twitter I just got the streaming fixed from sprint. Call them ( i did it over twitter) and mention the issue you are having. Mention the fix listed in their system below
CE Device portal listed as 'HTC EVO 4G (A9292) - Streaming multimedia applications receiving errors on software version 3.70.651.1'
They do something, and without rebooting my phone, or any changes on my part sirius xm now works.
I hope this helps.
The use of your MSL code in no way voids your warranty.
Having Sprint tech support walk you through things on your phone using the MSL is 100% ordinary.
The tech responsible for starting this rumor needs to shot.
You, on the other hand, need to be - Welcomed to the forums!
You came to the right place to get the square deal on the info, the straight dope, the lowdown and the truth.
You are fine. Your warranty is fine. You harmed nothing. You were not misled.
Nah.
As others have noted - what they had you do was they could do automagically, it just depended on the tech. Your phone's not in any funny state, needing to be hidden, concealed, or anything nefarious like that.
It had a service action, a problem was resolved. If possible, forget it by morning, really.
Besides - service tends to be quite able to do a hard reset, a software re-install and another trick that will set everything deep inside back to out-of-box, minor bugs and all.
Your phone is not the odd man out right now, it's all good.
I hope this helps.
