DGRYAN1977
Any advice on steps I should take before I download and start using it?
For example; should I delete everything off my current home screens?
Thanks for the tips!!
Only thing holding me back is no longer having friendstream or the news widget.
Are there things similar that I can download for LP?
Thanks
Thanks
Not really sure you need to delete anything. Couple tips b/c it can be confusing at first since it's a little different interface than Sense.
Once downloaded, to get it running, press the "home" key and the select LP (along with the remember setting checkbox) as the default instead of Sense, this confuses newbs. You may need to go through this same thing each time you get a market update for LP also. It's weird b/c you keep trying to back out of the market and it won't let you b/c it doesn't know which launcher it's supposed to use without you telling it again by going through the "press home key and reselect LP" thing.
Also, with Sense you drag stuff off the bottom of the screen to get it off the homescreen whereas with LP, you drag them to a trash can in the bottom/center of the screen. The can shows up once you long press and start dragging an icon/widget. Same principle though.
Again... just want to add onto this. LP has a built in uninstall feature which is quite handy, IF you realize it's there. When you drag things to the trash can there are two possibilities. If you drag and drop it quickly it will just remove that icon from your home screen. If you drag something to the trash can and hover over it for 2-3 seconds, it will ask if you want to uninstall. Just wanted to mention this so you don't accidentally start uninstalling your apps. It DOES give a confirmation window though before uninstalling.
Then I thought... well that's actually quite handy!
again, this is only available in pro plus, but its SUPER handy.
you achieve this by dragging half of the large widget off of the screen on any side (watch out for bottom because it'll delete the widget) then just resize to your liking.
