Root Solved? lol...Help battery wont charge
dmcjr22
Android Expert
Title says all all of a sudden battery wont charge ive tried two seperate chargers reinstalled backup rom and no charging weird thing is couple times when i plugged or unplugged charger i hear sound animation but sometimes no sound...dik whats up so help please 14% left lol
Yup ive bout tried every troubleshoot i can think of tried different outlets lol...battery status says good phone is about 4 months old and im at a loss as to whats up
EDIT WHEN PHONE IS OFF AND PLUGGED IN IT SOFT REBOOTS U SEE THE BATTERY ICON THEN U DONT REBOOTS AND REPEAT
lol ummm so now phone says charging and all off a sudden a car ico came up in status bar and i pulled down notifications and in it is says car mode enabled...what is this?
It's for driving, eg. All calls are routed through speaker, and etc. This is your problem. It's set up to only charge through a dc adapter. It's a voltage/amp reduction module. There should be an option for this in wireless and network. Not sure where exactly on your rom as I do not have your phone
ok s2 things under battery satus says chargiing and ac also i looked in settings like you said and are you reffering to usb connection because i dont see what you are talkin about...so new update it was charging and like i said but because im fiddling around to see the cause of this i unplugged it and said phone was charging on lockscreen and in battery status in the syystem settings but now not charging again
lmao my phone is possessed or gotta ahold of "daddys vase" cuz i unplugged again to plug in and even though said was not charging it gave sound animation of unplug and then when was unplugged said was charging... i wish i could give you guys a screenshot of this lol...maybe chev can implement a xbox kinect screenshot in megatron 6.0.5
im half way resolved or something like that check this out when im plugged in to outlet i get no charge no led indicator nothing but unplugg i get the sound effect however plugged into laptop i get charge even though usb not recognized device attached to this computer has malfunctioned...do idk whats up but atleast i can charge
Have you been into the hiddenmenu lately? In there, you will find an option for USB charging. See that was disabled somehow.
If your referring to the sytem settings/wireless network/more/usb conection know however when DaisFlaque gave suggestion i went there and was on ask on connection currently on mass storage cuz been tweaking around with them
Nope that is not what I am referring to. By the looks of your post, you don't know what it is. No problem. Are you on MegaTron and do you have your MSL #?
3 yes dont know what your refering to on megatron and can get msl just gotta find the post on the on what to enter in terminal emulator
Type in "su" (for super user access) then type "getprop ril.MSL" (then enter to get you Device's MSL code)
The above IS case sensitive.
USE AT YOUR OWN RISK
Open phone dialer.
Dial ##3282#
Press Edit
Enter MSL
Goto USB Charging and check enable if disabled.
Plug up phone. Hopefully it gives you the options to either bedside, clock, or dock nothingness. Choose dock nothingness. The car mode should be disabled now.
nope didnt do that i open it up and gives tutorial page but thats it no options to choose anything want to say that i did turn car mode off now taht i think about itwhen originally popped up i turned off in notifications
