Looks fine to me, although i prefer ext 3..
Good morning all
After a rather late and busy night I have my phone back to working order but achieved nothing.
SUroot, my Gparted showed exactly what my screenshot displayed as I hit apply from that. I'm still not sure what went wrong but I had to format the SD card and luckily I had my back up to cyanogen! My only thought is that my fat32 partition was the 1024 MiB and the rest was ext2 even though I read a stupid amount of guides and video's which alluded to me doing the opposite.
Could this be what happened?
As for flashing teppic's rom.. that's a completely different thread but neither the radio and rom would install, aborting after about 5 seconds. Very frustrating.
So the second time you mounted the sd card as usb mass storage, it showed exactly as it should?
Morning Shauny,
The error message I got was the following:
As for the radio, I was told that I didn't need to but it wouldn't be a bad idea to. I figured I'd give it another go for learning purposes and experiences. Ooops!
As for the SD Card, can you see any obvious glaring error I did what I am currently overlooking? It's quite discouraging as I don't really want to try again. I'm going to buy a 2nd SD card as my guinea pig I think.. I spent 6 hours lastnight doing one large circle and it's quite frustrating, but you guys are being as patient as ever!
Thank you all, by the way
PS: I got a similar error message with the radio
Windows can only see the first partition on a sd card.
So in the way you avoided my question, I assume you didn't go back into gparted a 2nd time to check? That's fine.
you are getting this error cos you are using a shit version of clockwork mod
if you are pvt 1,2,3 or 4 20000 erase size use cwm2.5.0.7
if you are pvt 4 40000 erase size use amonRA 2.0.1
do not use cwm 3,4 or 5. they are fail
if you are s-off use fastboot to flash recovery ( recoveries can be downloaded from the link in my sig) if you are not sure about fastboot use androidflasher
I didn't intend to duck the question, apologies.
I can't say with 100% conviction I remember anything which seemed erroneous on Gparted, so I assume it partitioned as per my original screenshot.. But long story short, I cannot honestly remember. But I pressed "apply". The only thing I changed was Ext2 to Ext3 as Shauny said it was the norm for him. I figured if it worked for him with Ext3, that's good enough for me.
Yeah the first screen shot was fine. What I.wanted to know was if something had changed or gone wrong which only revisiting gparted would have told me
Wow.. Why is nothing simple?
Is there any guides/FAQs regarding these processes? I feel overwhelmed by it all![]()
