I was mainly just going online, and into some news applications. I was using Wi-Fi (it was on and I should have been connected), and the screen was set to “auto.”
By the way...
I have just downloaded Fast Reboot Pro – it has all great reviews.
Anyway, I ran it and it said that it turned off like 14 MBs of stuff. Then, it said 17 MBs. Like, not even a minute later, it said 72 MBs.
Is this normal? What should it say? Should I set-up auto reboots? If so, how many each day?
What should my readings tell me every time Fast Reboot Pro is run?
I honestly recommend that people stay away from ALL of those types of apps that android can do on its own, like juice defender, all task killers, fast reboot pro etc.... Most of them have little, to no effect on battery life or phone performance and have been known to have adverse effects. Even if you believe they were helping before, an update to the app itself or ANY other app on your phone can cause them to start acting weird.
And IMO you are nitpicking your battery too much. Just let your phone run for a few weeks. Don't try and tweak it or monitor. Just let it do it's thing. You can't really compare your battery life in a specific scenario to someone else's, unless you were in a lab setting and all things being equal. But in the real world, all batteries are not created equal. If you bought two equally rated batteries, from the same manufacturer, from the same store, on the same day, they will not last the the same amount of time.
There are also factors out of your control (besides the ever degrading battery) that could be causing worse battery than before. Mainly signal strength; even a few DBs less can cause significantly more battery drain. There could also be increased network load on the tower your phone connects to, which in turn causes more processing time.
Basically, your battery stats are really not pointing out anything completely abnormal. So just ENJOY the phone and don't fuss over the battery.(plus constantly checking the amount of battery that you have left isn't helping).
IF your battery life isnt up to what you need, invest in a couple extra chargers or extra batteries. **IT IS A LOT easier then constantly having to worry about when your phone is going to die.**
