the GPS is a MUST!!!!!!!!!!!!!!!!!!!!!!!!!!!!! I cant believe they told you its a "option"...
the GPS is used to tell the local terrestrial network where the handset is. since the local towers cant "see" the handset due to the airvana, the GPS sends coordinates to the network so your calls get routed and so you are able to be handed off from/to your femtocel to the local network and vice versa.
good job on using your GUT!
I tried calling them and they had no solutions other than reset and restart and that didn't help.
