Bootloader
Hold down the Vol. Down button, Trackball, and Power button at the same time.
This should be on the Boot Screen
nHBOOT
<VOL UP> FastBoot Mode
<BACK> Simlock
<HOME> Recovery
Hard Rest
* Hard resetting the device deletes all data, including downloaded applications, and resets the device back to its initial state—the state before you turned on the device for the first time* (You've Been Warned) Make sure to back up important data you have on the device before you reset your device.
Using the Hardware Keys
Power the Phone Down (Hold the End Call button down until you get a pop up window to power down)
Hold Home and Back keys at same time
Without releasing Home and Back press the End Call button (which is the Power button) and release the End Call button.
You should still be holding Home and Back and now a screen will come up asking for an action. Press the trackball to reset or back to cancel.
Press trackball then it will ask you to press menu to reset and it will be factory original!
Using the Software Menu Option
Menu > Settings > Privas
cy > Factory data reset > Reset phone > Erase everything (Wheres the fun in this)
Soft Reset
*This will gain some RAM back if device becomes a bit sluggish and will NOT DELETE your data*
Call Key + Menu Key + End Call Key = Restart / Reboot
Or the Old School Way
Simply remove the battery and put it back.
nHBOOT
<BACK> Simlock
<HOME> Recovery
Hard Rest
Soft Reset
