Root [Sprint] [OUDHS] Soft Brick and CWM recovery support
xInterlopeRx
Ok, some of you guys are really tearing it up and trying some stuff that can soft brick your Victory. A soft brick is when the device will not boot into Android OS, but will boot into either recovery or Download mode. Download mode is the screen with the yellow triangle and the digging android. Another screen you might see is the one with the error message and the computer connected to a phone. That screen just tells us that whatever was just tried failed. For our purpose though, it is the same as the download mode screen. Usually you see it after a failed flash using Odin, which we will go over in a minute. Both screen open the device up to be flashed via USB with either Odin (if using Windows) or Heimdall (if using Linux). These are tools that allow the user to install software to the device by writing the data to the proper partition.
You can usually get into Download mode by holding the volume rocker down while also holding the power button. You can escape download mode by holding the power button down for a few seconds. I do not recommend removing the battery to escape Download mode. Try the power button for a while before you chose to remove the battery.
So, now that you know what we're working with, here are some files you may want. The first files are the stock kernel and recovery. Most devices call them boot.img and recovery.img respectively, but to work with Odin they need to be contained in a .tar.
Download them before the power goes out!
Stock kernel
Stock recovery
You also want to make sure you have the right drivers for your Samsung device. When you first plugged it in, Windows might have installed some generic drivers, but that's not good enough for us, so download these drivers and install them right now even if you don't plan on flashing anything or working on your device at all.
Samsung drivers
After you install the drivers, plug the phone into the computer with your USB cord and let the install finish completely. Once that's done, you are ready for BaconMaggedon!
Next you will want to familiarize yourself with the Odin program. Get it now!
Odin 3.04
Extract the zip. Double click Odin.exe. You will see a series of "windows" in a row across the top. On the left, under the first one it says "ID:COM" The rectangle beneath the letters should turn blue when you plug in your phone. Try it now to make sure; there is no danger. This ensures the drivers are installed correctly and you are ready to fix or modify you device. Doing this now will avoid a headache later. If it does not turn blue, try using your USB in another port.
Next is the scary part. As of this writing there are only a few files you can use with the Victory. The stock kernel and recovery from above and the next one, which is a modified recovery, and a community favorite, ClockWorkMod. Download it now!!!
Victory Clockworkmod Recovery
This recovery will allow you to make a full backup of the system, data, boot and maybe some other partitions as well as wipe partitions clean. If you wipe system let me know. I have to upload a file to recover from that.
Now, to use Odin, fire it up if it's not still on. Plug the device into the computer using the USB cable. Check for the blue rectangle near ID:COM and make sure "Re-Partition" is NOT CHECKED OFF!!! I repeat NO CHECKMARK!!! Once you know the device and computer are connected properly, click the button labeled "PDA." You will now see a file explorer window. Navigate to the desired file and chose it. File explorer will disappear. If you are sure you want to proceed, click "Start" at the bottom of the program window.
In the message box, lower left corner, you will see what Odin is doing with your device. If all goes well, there will be no error messages and the device will reboot into the Android OS. If not, and you get some kind of error, this is the thread to discuss fixing your device.
Please give as much detailed information as possible about your situation in your first post. Avoid messages like "I was using Odin and messed up my phone. What do I do now?" I have no idea what happened, but want to provide the best support possible. Copy any error messages you see exactly and describe how you arrived in your situation. If you need intense help, join the IRC by clicking the link in my signature.
Happy Flashing and good fortune to all!
UPDATED LINK AGAIN!!!! I can't find any bugs, but I switched to TWRP so...let me know.
EDIT: All the links are broken because I moved the files to the new OUDHS website. You can find anything you need here:
http://www.oudhitsquad.com/android/
Some larger files, like the stock firmware, I haven't uploaded yet, but we'll be back up to speed ASAP.
So I just got my hands on a Samsung Galaxy Victory 4G LTE...and me being a dummy, I started playing around and using odin to flash a recovery to it thinking it was closely related to the SIII....well the end result was a touch screen that won't work anymore. I grabbed the stock kernel and bootloader images and flashed them to it, but same result....the touch screen will not respond. Can someone help? I don't want to end up having to put this phone in the graveyard forever.
EDIT: Probably gonna have to wait for a full ODIN to be released. *sigh*
I'm currently selling a rooted victory with everything working, if your interested in buying
Hello Victory users!I am looking for feedback on mounting options. Can someone please try to mount everything and make note of it here so I can fix it if necessary? Thanks.
In what order do I flash the files? Or does it matter?
Sorry, I was on vacation. If all you want is CWM recovery to make backups, just flash that file and go have an ice cream. If you want something else, you'll need to provide a bit more detail.
Strange
Completely stock
Ran root.bat successfully.
Odin CWM successfully.
Tried to flash update failed.
Restored to stock recovery successfully.
Flashed update successfully.
Tried root batch failed.
Wiped all data and Odin back to stock files successfully.
Tried update via stock recovery failed.
Wiped and Odin back to all stock files.
There is no longer a "Check System for Updates" option in settings anymore.
Any way to get back to 100% stock?
or
Any way to force update.zip?
I'd prefer to have the update more than rooted but I can't get to either now.
I believe your f'd until someone does the backup from jb
when that gets done, copy backup files to sd, and you would just need to "advanced restore" just system, maybe boot too just to be safe, and your update should be perfect as long as you have CWM already installed
I'm back to stock system and kernel (4.0.4) and back to stock recovery too. Everything is working fine, it's just that the "system update" option is gone in settings and I now have 3 ticks on the ROM counter.
I cannot connect to Kies but I assume that's because of the edited system files.
The files I used are all listed here:
waywardpilgrim.net
waywardpilgrim.net
Any chance of u flashing cwm and doing a sys d ump of that?
If you're willing to walk me through the process a bit, sure. I have no problems loading CWM again.
I assume there's an option once I load CWM to create some kind of file/dump?
Just install CWM make a backup as usual and grab the system and boot imgs and upload them somewhere, that's just about the whole if it
you should be able to do fastboot -S 0k system system.img.ext4 from the bootloader. Just DL the file from my archive. HeroSandwichMax can help you with that too.
im on jb is there anyway i can for cwm other then odin. everything passes but it still shoots me to stock recovery. i would love to make a system dump of jb for the victory.
dl file from: http://www.waywardpilgrim.net/android/samsung/sph-l300/mod/recovery/victory-cwm-recovery.tar
extract recovery.img to root of sdcard (/sdcard/recovery.img)
open terminal emulator or use adb shell
obtain root via command "su"
do:
cd sdcard
dd if=/sdcard/recovery.img of=/dev/block/mmcblk0p18
should say writing blocks at bla bla
then type "reboot recovery"
profit
I took xInterloperx's recovery.img, opened it up, found mount points, and found the recovery location
Thats because the kernel crashes and gets overwritten by android failsafes. I need a JB kernel to do the job. Get me that kernel, and it'll get done. I have the source, but will need testers. I will start a JB recovery thread when I'm ready. It'll be a few days at least as I'm kinda backed up with like 6 devices right now. Sorry it's taking so long to get support.
how do i pull a kernel?
use choice of terminal (term emulator from play store OR adb)
obtain root via "su" command
type: "dd if=/dev/block/mmcblk0p7 of=/sdcard/boot.img"
then go to sdcard and copy that boot.img (contains ramdisk and kernel)
Syntax: "dd" is the gnu? tool for image flashing or pulling, su obtains superuser rights, and if means input file and of means output file, so "if" the partition of boot which contains kernel and ramdisk and "of" creates the boot.img
:D
btw here is the table from recovery.fstab which lists all partitions:
# mount point fstype device [device2]
/boot emmc /dev/block/mmcblk0p7
/system ext4 /dev/block/mmcblk0p14
/data ext4 /dev/block/mmcblk0p15 length=-16384
/cache ext4 /dev/block/mmcblk0p17
/recovery emmc /dev/block/mmcblk0p18
/sdcard vfat /dev/block/mmcblk1p1 / dev/block/mmcblk1
/efs ext4 /dev/block/mmcblk0p11
/modem emmc /dev/block/mmcblk0p1
DO NOT pull /system using dd!!! I have heard bad things when this is done
Device storage is too small for the system partition unless you send it to the extSdCard location. If you really want to help chavezkyolio, hit the link in my signature and we'll do some chatting in real time. Just one hit, one little hit...whats it gonna hurt?
I'll be completely honest with you; that's over my head. I'm comfortable with anything that involves flashing via Odin or CWM or TWRP. Beyond that, I'm one of those folks that shouldn't be doing what I don't know about.
This is my daughter's phone so gimme a bit of time so I can pry it away from her hands long enough to flash custom recovery again and get the 2 dumps requested.
I have a Note 2 and perhaps I got spoiled with the amount of ROMS and the toolkit to customize so easily. I appreciate the amount of time you guys spend doing the work with these less popular phones!
