Root Still no GB
You should be able to pull it from what I've heard. Go to menu>settings>about phone>system updates and it should find the update and download it for you.
I haven't actually done this myself but it's supposed to work from what I've read.
I been trying it since the 4th.. nothing at all.
A to be honest, this phone has been pissing me off big time. It is slower then ever.
What does it say when you hit "Check for Updates"? Does it say "Your phone is up to date"?
If it's anything other than "Your phone is up to date" then it's an error and the update is available, but your phone isn't finding it.
I guess I could do that..I was once rooted then unrooted..had roms then went back to factory.. I wonder if any of that has to do with it..the phone started running bad about a month ago..
Yeah you could do what binary said.. or just root it again use that same link to get to .596 then try some GB roms :D
its been awhile since I had my phone rooted.. Is z4 still the way to go or should I do it the old way? When I used z4 I remember my phone always using all the cpu and that was the main reason I unrooted. The phone ran like shit
If you're running 320 you're rooted, so I'm going to move this to the root section. :)
I just did this yesterday and it downloaded and installed just fine.
First I sbf'd to 2.3.340 (because I was already on rooted 4.5.596), did the OTA update by going to System update and forcing/pulling the update; afterward I had to sbf back to 2.3.340 and install the 2 part update to get back to rooted GB :D
