Root Stuck on Clockworkmod Recovery!!
erik917
so i was rooting my phone . first i unlooked trhe bootloader then i installed the Clockowrkmod but once i installed it i cant get out of it! i click on reboot system now but once i click on it i reboots and takes me to the clockworkmod recovery
Simply locate a custom ROM you like download and put on your SD card since your already in CWM you can go to install zip from SD and it will flash the ROM remember to wipe cache and dalvik cache and even a factory reset
the probelem is i have no custom roms in my sd card and i cant access my sd card since the htc one s doesnt have a spot to take it off. is there a way i can mount it on while inrecovery mode and then add a rom to the sd cardon recovery?? or what shold i do?
i know huh:( i just really need it to work ! if anyone can help me fix this i would thank u SOOO much! i just bought this phone!
Erik,
Thanks for the heads-up, StarScream2109...I've reached-out for help for Erik, so hopefully someone might have another idea that will help.
By the way, Erik, how did you flash CWM? (via ROM Manager or manually via fastboot?)
Cheers and best of luck!
Thanks scary :) ill be here until this issue is resolved
And it sound like he did it fast boot but I may be wrong
No problem!
BTW, the adb daemon is always running while in a custom recovery, so he should be able to push and pull files with adb and/or even use an adb shell to poke and snoop-around...
Cheers!
Erik,
i did it manually
