Root Stuck on Clockworkmod Recovery!!
Okay try using adb to pull the system scary you might know the exact procedure
so what should i try to do now?
Reinforcements should be coming...let's hold-tight for the folks that might be familiar with this issue (can't promise a timeframe, though, but better safe than sorry).
This is not a device I have personal experience with, so I'll leave it to those that do ;) :).
ADB is android debugging bridge I don't have a lot of experience with it :( I've used mini ADB when rooting my Droid Incredible
I bet someone with the know how of this device will pop on (since its an HTC ill send Scotty a.message he might be able to help)
oh good! ima start praying so he can be able to fix this problem!! i really really hope he can!!!
You should be able to mount the internal sd card to your pc from CWM. Take a look in the mounts and storage section (in clockwork recovery) and you should see the mount USB storage option. If you have the phone plugged into your pc, the internal sd card should then show up on your pc. You will then be able to copy a rom to the "card" and unmount the storage and then install the rom from CWM.
I'll see if I can find a how to guide for you.
At about 2:40 minute mark, gets into installing a rom
http://m.youtube.com/#/watch?v=WheipGMptg0&desktop_uri=/watch?v=WheipGMptg0
If Scotty is on his way, I won't even bother trying :p But I thought I could at least have you start downloading the RUU for your phone. I have a feeling he might make you run it! What country are you in and who is your carrier? I will try to dig up the file so you can start the download. It's a big file.
my phone is tmobile but i have it on simple mobile. n how will i download RUU?? im in the US in TENNESSE
well i tryed that but i click on it and it says unable to open ums lunfile something like that
Hold power + Volume down until it shuts off, then hold them both down again and you should be on the hboot screen. From there you can select Fastboot, then Reboot (Use volume to go up and down, and Power to select). I have had mine get stuck in recovery and that has fixed it for me.
If you did a factory reset via CWM you won't have an OS to boot to though, so you will need to flash something else via recovery. You can mount the sd card via recovery like sdrawkcab25 was mentioning.
I would recommend flashing TWRP2 recovery, while in fastboot (like you did for CWM) the specific instructions are here: http://androidforums.com/one-s-all-things-root/543328-how-unlock-bootloader-install-recovery-root-your-htc-one-s.html#post4777154. Then you need to flash a ROM if you wiped your previous one.
how long to i leave it the + button pressed? cause i leave it pressed for about 30 sexand then as soon as i stop pressing it the recovery shows up again
It should take about 10 seconds to shut down (holding the power down will simulate a battery pull). Then it shouldn't take long to boot when you press it the second time.
