i have an issue i hope someone can help me with
***unlocked***
supersonic evt3 ship s-on
hboot-2.18.0001
microp-014f
touch panel-atmel224_16ab
radio-2.15.00.12.19
dec.21 2011, 12:50:32
ive used the htc dev to unlock but now when i try and use the adb shell i get an error of device not found. i have andriod sdk installed and still no dice. id like to either get it fully rooted into the revolution 2.16 so that i can put mikg3.0 and the anthrax kernal on it.. currently on it is cm7.01 and amon ra 3.11... what happened after i unlocked and flashed cm7 and clockwork the first time around something happened with the radio i guess bcuz i wasnt getting any rings when someone called or texted me.. id get notifications to voicmails and text but my phone wouldnt ring.. so now im trying to fully root or at least get it back to stock so that i can at least use it... in the interim i had sprint activate my old phone so that i could recieve calls and what not.. so do i need to have sprint reactivate my evo b4 starting to continue the rooting process? or can i do everything first then reactvate? i need my evo back and ive looked everywhere for info to have the command line adb shell work again and nothing so far. i was using captain throwbacks tutorial from the mik mik forum.. everything was good untill telling the phone these codes:
cat /sdcard/flash_image > /data/flash_image [ENTER]
chmod 755 /data/flash_image [ENTER]
/data/flash_image misc /sdcard/mtd-eng.img [ENTER]
after the last code it started saying directory or files not found and they are on the sd card. phone was not seeing sd card at all.. then i found the cmd line code for the phone to read it again. so now good except i get the device not found in adb shell...
anyone know whats going on with it??? thx
***unlocked***
hboot-2.18.0001
microp-014f
radio-2.15.00.12.19
