Root Stuck with device not found in adb shell cmd line
yea wierd thing is it doesnt see the pc36img on the sd card.
well sprint is mailing me a new device.. will get it today... hope its a new and not a refurb, or banged up... and most of all, an older boot. pref a 2.15 or a 2.16, then its on with revolution....
are you naming it correctly? windows hides extensions by default so if you add a ".zip" to the end of the name then in reality it will be PC36IMG.zip.zip which will not work. or if you have it setup on your computer to show extensions and you are not adding a ".zip" then the file will be named PC36IMG and that will not work as well.
also you are not placing the file in any folder, correct? if you do then the bootloader will not see it.
