Root Stuck with HTCdev
LinnEVO
Hi, new to this forum. Im trying to root my evo 2.3.5, im new to all of this. Idk if im stuck at or what. When I start my phone in bootloader mode, I highlight FASTBOOT and press power. Then it brings up
BOOTLOADER
REBOOT
REBOOT BOOTLOADER
POWER DOWN
If I press power when BOOTLOADER is highlighted, it just goes back to
FASTBOOT
RECOVERY
CLEAR STORAGE
SIMLOCK
HBOOT USB
BOOTLOADER
REBOOT
REBOOT BOOTLOADER
POWER DOWN
FASTBOOT
RECOVERY
CLEAR STORAGE
SIMLOCK
HBOOT USB
What does the first screen say before you go to fastboot? gives us the hboot and the s-status
you need to be in fastboot to do the command in the HTCdev method. when it says bootloader as an option that is the fastboot screen. from there on your windows command you enter the command:
Code:
fastboot oem get_identifier_token
Code:
that worked, thank you. i was thinking my phone had to be turned on and was wondering why i wouldnt. got my token key. thanks much
Code:
Yeah I havent kept up with the newest root method. I have mine rooted from the revolution way and haven't rooted a phone since mine.
