Do you see a red and green byte counter at the bottom of the window?
Is your wireless network list configured to view adhoc network - in network and sharing center click connect to network and "show all" dropdown box (vista)
This is my first post via WiFi Tether.
I connect and it doesn't ask for a password but I cant use it.i think torrents are blocked. based on a conversation from a previous thread.Has anyone been able to use this app to download torrents?
Hello Everyone you first off before I ask for help I wanna say that you people rocked this thread!
What I need help with is the fact that I followed every step down to the t but when I try to connect to the indulge hot spot.
I see it as a hot spot to connect to it, that caution sign is right on top the the signal strengthI connect and it doesn't ask for a password but I cant use it.
please help ;(
Are you using access control?
If you go in the Android Wifi Tether settings, you will see the Access Control Options. If you enabled it, make sure you are whitelisting your computer/MID so it can use your 4g signal!
Also, make sure you select as device profile Samsung Galaxy Indulge (Or Evo, if you have the old version)
I live in LA and for some reason when i ran a speed test while tethering, speed test.net chose florida as the nearest place to me..... why is that?
My phone is rooted and wifi tether works. But after a while maybe like a hour or so my phone will just shut off and I'll have to turn back on.
Is anyone else having this problem? If so does anyone know a way to fix this.
I know my phone shuts down when it gets too hot from running games
heavy in graphics..that being said when you tether the phone gets very hot !
This overheating of the phone cannot be good for the phone if you ask me.
My phone's not even hot when it shuts off. I took the back phone cover off and just have my case on it. It let's it breath more and the speakers louder. It's helps I deff recommend doin this.
