I'm looking to upgrade my rom to the superclean 2.2. Right now I have DL09 with Super clean 0.4. My understanding is that superclean 2.2 also contains the kernel needed. I can't seem to find a working clockworkmod link for the new clockwork but was considering going to the superclean 2.2 voodoo anyways which from my understanding has it's own clockworkmod already packaged in? Would it be correct to assume I could do the following:
1. I've already used the old cwm to back up and backed up my apps on titanium backup.
2. use odin to push the EB01 radio
3. flash the superclean 2.2 voodoo
4. flash the revolution theme that I want to get
5. then make a new backup using the new cwm that comes with superclean 2.2 voodoo.
Does this sound correct? I just wanted to double check my knowledge from reading through some walkthroughs. Do I still need to flash the new cwm? Does any one have a working link for the new cwm? Thanks for anyone's help.
. Although even that can be undone via adrynalyne's mighty all in one odin] But make like easier and keep voodoo to voodoo or non to non
. Both times I wiped data/cache too...like 3 times. Maybe this will help? I dunno. If not, I might just odin back to di01 and start fresh.
