I move all my nandroid backups to Dropbox, which saves lots of space on the SD card.
You have to transfer the files back to the sd card before being able to use them.I may try dropbox, seems easier than going back and forth from phone to computer
silly question time:
can you run a restore .zip from clockworkmod from dropbox, ir do you need to transfer it back to your sd card?
Wow, what a great idea! I never thought of this. I assume to put the nandroids back on your card for a restore you just place them back in the clockwork folder via disk drive mode?
BTW, just saw you're from Boston. I live in MA as well. Go Pats
