I would like to know how to hide widgets when you select a springboard when those widgets are not associated with any other springboard. I have the beatiful home widget when I select a springboard
Is anyone using the latest 712. Must of been released today. I updated to 705 yesterday.
I installed it just a few minutes after it was released ... LOVE IT! This app is really starting to "get there".![]()
Another issue: on bootup, nothing will load - only the notification bar - until I press the Home button.
Then Handcent will FC, then SH finally loads.
Is anyone having problems with the proximity sensor disconnecting calls? Wondering if it's an SH2 or Android problem.
It seems to work fine on the native home screen. Basically, I choose dial and when I put it to my ear the call drops and I get a call screen with no icon or number and if I press the red end key nothing happens.
Got a new phone from Verizon today then figured out that ES Task Manager was causing my problems. Causing widgets to not update as well.
I have one big problem. I got my new phone and loaded all the apps I could remember. I then loaded SH3 712 and all the apps that where not loaded showed up as marketplace icons. I downloaded the apps reinstalled them and they still have marketplace icons.
I do not know what to do at this point. I have removed the shortcuts and reinstalled the apps and they still have marketplace icons.
Yikes! What a mess! Did you try going into edit mode, then doing a "hard refresh"? I don't really know what that feature actually does, but it's worth a shot, eh?
