Psychokitty
...Loading...
Great theme, Joe!
So I've read a few times about the 4-5'ish second delay when pressing the Home button. Is there any way around this?
That's an image caching thing. I know you solved itI have one big problem. I got my new phone and loaded all the apps I could remember. I then loaded SH3 712 and all the apps that where not loaded showed up as marketplace icons. I downloaded the apps reinstalled them and they still have marketplace icons.
Shouldn't need to reinstall though, a simple restart should solve it.
)I am missing something basic, what program is used for the tags to tag apps in Sweeter Home 2?
Having some trouble figuring this out, yet, it sounds extremely simple - although I will admit I have not been able to spare time to go into every menu and selection, so I hope the pre-emptive question is not a bother (usually try to exhaust my ability to find information before asking, but work blew up yesterday on a project I won't see the end of until Friday, so I lost a ton of steam)
That's an image caching thing. I know you solved itShouldn't need to reinstall though, a simple restart should solve it.
I've noticed when I reload my theme after installing a new build of SH2 I have to reinstall my widgets. My tagged trays are good and custom trays with embedded on are good, but my widgets are blank. Is there a way to avoid that?
I was not aware that an app could only reside in one tagged tray. Kinda makes sense . . . but I could see where some wouldn't like that.
Edit: Figured it out, it has nothing to do with editing, which makes sense. You just click and hold and do it like adding a widget but you add an app. You rock Joe!!!
Oh what beautiful widget skin do you use to get the background to be transparent? thanks again and sorry for blowing this thread up I just rooted and OC 1ghz last night and then was waiting for this and I'm so excited!!!![]()
Thanks pinesal, but I do save my themes to my sd card which is why I thought it strange my widgets didn't carry over. But if I'm the only one with the issue then there's something I'm not checking off and I'll figure it out eventually![]()
I edited the SenseUI skin to have transparent backgrounds. Yea, I think that looks sick!.
And I know I asked before but how come your theme when I downloaded it, is not the red dr pepper looking one, it's the normal droid bg file for all backgrounds.
Background files aren't included with the themes. But the one he used in Dr Pepper looks like one of the default ones that you can switch to yourself.
