so every phone is different, so what works for me may not work for you. with kernels you really just need to try one and see then move on if it does not work for you. remember to always make a nandroid backup. i would start with the aggressive freedom kernel and then move on from there. always give a kernel a few days to settle in before deciding to move on.i am making the move from mikg 2.59 over to mik3d. i was wondering how you all have it set up. kernels? setcpu? v6 supercharger? i want to try and suck out every ounce of battery i can. thanks in advance!![]()
same goes with setcpu. on my evo i can go as high as 1190 without any issues, but for some that would freak out other phones. so you really just need to play with the settings. also try and use smartass or interacive x as a governor.
when you say "freak out" do you mean sending it into an infinate boop loop? mine has done that on mikg a few times but as soon as i turned it down to 998 it seems to have quit.
