Help swype.apk
Rally 517
Android Expert
Anybody have a link or where can I get. Put CM7 on my girl's phone and she like swype from simple blue better that's than gb keyboard
...is the correct (and only) answer if it's not preinstalled on your handset.
I shouldn't have to remind members that sharing copyrighted apps is prohibited by the Site Rules.
ok so I have been using hroark13's clockwork and cyanogen, props and kudos to all who worked on that.
I had not previously got swype working correctly, so I tried all the usual, with the obvious outcome.
Before getting the beta I used root uninstaller to remove then rebooted the phone.
I then tried downloading the beta, had to dig up my account info from when I had a g1. :)
The installer worked fine but when it tried to start it force closed.
So here is the things I tried to make it work.
1 install beta -- force close
2 reboot phone -- force close
3 reboot to recovery, clear dalvik cache, clear cache, wipe data/factory reset
4 reboot 2x (getting out of recovery)
5 login to google market
6 open file manager navigate to /sdcard/downloads
7 install Swype-Installer.apk
8 log into swype account
9 selected swype americas, then works!!
this is what I had to do, mostly do the factory reset and then install
hope its useful
travis
hope its useful
travis
when i first tried it the only way i could get it to work was on "all nations" or whatever they call it. but then after in uninstall and reinstall i was able to just pick "Americas" its weird, not sure what causes it.
