droidkevlar
Android Expert
if i use this 'Swype' would i be able to use it with handcent SMS? i would like to use the swpye keyboard with the handcent app.
You can use it for any app. I use it with handcent and makes texting SOOO much better.
so i installed swype everything went well but when i set it to use it wont open it just opens as the stock keyboard
if you read the above posts, users have explained that already, just hold click on an input box and select the default as swype.
someone answer my question regarding the Swype compatibility with handcent please lol. thanks!
)I really liked this keyboard but It force closes on me way to much.
from what I noticed it would force close when I held the backspace button.
Also when I went from regular keyboard to landscape sometimes it would fc on me.
I hope this helps the developer and he/she is able to fix these they would get a lot of bussiness from eris users I believe.
alright alright i'll try it... quit pushing.
tho i do like better keyboard, but (i'll prolly get yelled at) you cant drive and txt with it easily
