Needs auto spacing and auto caps.![]()
It does do auto-caps. Touch the letter you want capitalized then drag your finger off the keyboard and back on. Perhaps you should do the tutorial under the Swype settings.
I gotta agree with everyone else. This sent my typing speed via the OSK through the roof.
capitalization isn't working for me. I swype above the keyboard as the tutorial shows but the word is not capitalized.
any suggestions?
also, there isn't any auto space after a period.if you tap period and then do the next word, the sentences run together, as above.
once they fix a few things this could be great. quickly revising my original opinion.
also, did you guys find the copy paste keyboard? very cool!
That's not really automatic. It should auto capitalize after a period like the stock keyboard.
Thing doesn't work after install, just beeps and flashes a blue border...
Does anyone using this have a screen protector on??
Regarding swype, or shapewriter, is there an option to restrict its use to portrait mode only? I like the idea, but I'm not sure how much I like it for landscape.
the autospace had to be turned on in settings for me, maybe that is the issue for you
I was thinking the same thing, I like it in portrait mode but prefer the stock keyboard for landscape.
Thanks...yeah, Autospace is already on, and it works fine between words.
It does not work at the end of a sentence. Type a sentence and put a period at the end. Then start the first word of the next sentence...Swype will put the work right next to the period, so it looks like the example below, with no space between the period and the "G."
"I'm tired and am going to bed.Good night."
If anyone has a different result, let me know and maybe I'll try a reinstall. But for me, Swype does not put a space after a period automatically.
It showed in the tutorial to swipe the period left to the space bar. That will give your space after the period.
Sweet dreams
